8 booms or 4?
Discussion in 'Cinestar Misc' started by Jonathan Ross, Dec 5, 2014.
  1. Jonathan Ross
    Jonathan Ross Member
    Jul 29, 2014
    113
    10
    Hi All,
    We are about to invest in a new copter and we were wondering if anyone can give us some feedback on a question. Is an 8 boom single prop system more stable and easier to fly than a 4 boom with dual inverted motors on each boom. We are looking at two different heavy lifts from Quadrocopter and could use some advice.
    Thanks,
    J
  2. Steve Maller
    3,975
    I'm a fan of the X8 config. Among other things, it's more compact and you can run bigger props on it without concern as to them hitting one another. I find it to be more stable, too, but it's kind of apples vs. oranges because I was running completely different power systems on my flat copter. There are downsides, including the inability to grab it out of the air (ouch), the higher probability of props appearing in shots, and possibly diminished structural stability at very high AUW. But after weighing the options, I voted thusly.
    http://forum.freeflysystems.com/ind...ium-heavy-lift-8-10kg.3079/page-13#post-43762
    [​IMG]
  3. Jonathan Ross
    Jul 29, 2014
    113
    10
    Thank you Steve great feedback. What do you think about the T-Motor Heavy Lift Motors MN4012 do you have any info or experience? I have found what looks like a solid copter to replace our other and these are the motors. They are also using a Gryphon Dynamics Octo Power Distribution Board. I need to lift 12 lb. easily. I appreciate your help sir.
    Cheers,
    J
  4. Steve Maller
    3,975
    I don't know anything about those motors. I'm a KDE guy. But lots of folks (including Quadrocopter) use them.
    By 12 pounds do you mean total payload, or just the camera system?
    And nothing with multirotors works "easily". :rolleyes:
  5. Jonathan Ross
    Jul 29, 2014
    113
    10
    Yes, we have a Cinestar 8 and it flies great but it will not lift our payload of 10 lb. without a serious upgrade so I am looking at options right now Yes, I meant 12 pounds of payload aside from copter. QC says they this set up is built for 12 lb. payload I'm just looking looking for as much feedback as possible. I especially like the idea you shared of having more space between booms for props. Thanks again Steve.
    J
  6. Mike Peters
    Mike Peters Member
    Apr 4, 2013
    45
    I'm considering turning my HL CS8 into a HL CS4. I refuse to fly a small quad with a GoPro or other "cheap" camera. I'm currently using 6S batteries with 8 MN 4014 motors with 14" props. I want a smaller "bird" that will still fly a Movi and a DSLR. If I shorten the booms and go with 15" props on a quad config what does everyone think about the lifting capacity?
    Thanks,
    Mike
    P.S. I'm not a math major....
  7. Steve Maller
    3,975
    By quad do you mean four motors? Or do you mean a coax X8 octo?
  8. Mike Peters
    Mike Peters Member
    Apr 4, 2013
    45
    I mean a quad - 4 motors. I was thinking booms about 300mm.
  9. Jonathan Ross
    Jul 29, 2014
    113
    10
    I would stay away from a quad and work with nothing less than 8 motors if you want to assure safety for your rig and gear. If you lose a motor on a quad you are toast. I am an 8 rotor kinda guy though so I am biased. Hope this helps.
  10. Mike Peters
    Mike Peters Member
    Apr 4, 2013
    45
    Jonathan,
    Biases are fine. I guess I could go the X8 route, but my goal is to reduce the overall size of the craft. What about 300mm - 400mm booms for an X8? I would still stick with the MN-4014 motors and 15" or 16" props.
    Mike
