Midway through a shoot today, the M10 started giving us the dreaded three blinking green lights. Per the manual, we have restarted several times, changed batteries, reset everything to factory defaults - nada. Can't find any loose connections on any of the wires. Anyone have any other thoughts or things to try? Help is greatly appreciated.
I'm assuming you are keeping the rig still during initialization? If so, and you are still having the issue, then filing a ticket with support@freeflysystems.com is likely the next step.
I'm sure you've checked everything, but when you're checking your connections make sure you're getting the ones into the motors. The connectors are tucked in behind the CF guard so you can barely see them. They can rattle loose on a flight though.
