Hello guys! Nice to be here sorry for my english, i try to do my best. I am building a handheld gimbal for 3 months now, i spent hundred of hours to make it better and better, i already had great results you can see here: so that was 2 month ago, it worked, not perfect but worked. So i decided to make a BIG gimbal to hold Epic cameras too, and here comes the present. I already has big motor cages, ready assembled the gimbal, and tried 2 different motors: HiModel Z92-150T motor and DYS BGM8108-90 motors.For my smaller gimbal i had Iflight motors (5208 180t) for all axes. So i tried to change the PAN and ROLL motors to the bigger motors i mentioned. Well.. i cannot feel really mass difference, its like just a bit more, but not too many juice from this motors. Also the DYS motor (9 OHM) is going to really really hot after 5 minutes if i put the power over 200 That is normal? If i try it under 200 than its same weak like the 5208 motors. My questions: So i am thinking to buy the IPOWER 80**serie, but it will be stronger? I really read a lot on forums, but please anyone write down is there a significant difference between the 5208 smaller motors and the 80** bigger motors torque with alexmos? What is the difference between IPOWER 8017-12T and 8028-90T? Also other people having this heat issue? with the ipower? Mine (DYS) is really hot, and i dont know that is normal for all type of BIG motors or just with this. I am using alexmos with extension board, 4S lipo. So what is the best motor for this task? with alexmos 4s lipo. Thank you Andrew
