Hi all, just updated to 3.08. All went well but now noticing that it does not boot all the time. Getting 3 flashing lights, connect to the Configurator and it give me fails on GPS, Compass. Reboot and reconnect to the Configurator, take 2 times each and then the Movi works. Then disconnect from the Configurator, if I turn off immediately and turn on it boots. Then if turn off again, wait a few minutes and turn on, the darn thing doesn't work again - 3 flashes and have to keep rebooting/reconnecting. Any suggestions? Thx, J
Hi Jason, This happens to me quite a lot. Seems to me that if there is any movement in the gimbal at start up, even a small gentle swing in it's stand it will not boot but after I've steadied it it is fine. This is the same as most gimbal systems I think. Hope that helps. Pete
Thanks Pete. Never had it happen before on previous firmware. Now on 3.08 it happening all the time even w/ being stable. Going to reflash 3.08 later today & see if it solves it?
Yeah was just looking at that Like i said above, just weird its never been an issue. Now it is after 3.08 even if there is zero movement? Re-flashing later today and hope it corrects its self. Thx, J
