3.0.8 Firmware update problem
Discussion in 'MōVI M5' started by lee ju sung, Jul 17, 2014.
  1. lee ju sung
    lee ju sung New Member
    Dec 10, 2013
    Hey
    I updated the firmware, but halfway through failure, showed no connection, I reboot and then connect
    But when I put the M5's power switch off and then back on, three LED flashes only once, not bright
    Did not respond, can not perform the firmware update, how can I do?
    a song
    Song: Please change your user name to your first and last name.
    Also, email to support@freeflysystems.com for additional support regarding the upgrade.
  3. Gary Haynes
    Sung did you update your GUI app to 1.552 before doing the upgrade?
  4. Conrad Piccirillo
    Conrad Piccirillo New Member
    Jun 27, 2014
    I had the the exact same thing happen and I have a shoot tomorrow.
    They're overnighting a cable. I would calmly say, the website is rough, the firmware is rough, the bluetooh is really rough.
    Other than that it's been a painful time with the Movi 5
  5. Steve Maller
    Just wanted to report that I followed this procedure:
    • Downloaded newest Mac configurator
    • Downloaded firmware update
    • Quit all open Mac apps
    • Started up MōVI M5 with gimbal turned off using DX8 transmitter
    • Verified good battery levels everywhere (MōVI, Mac)
    • Connected to the MōVI
    • Saved current configuration to the Mac
    • Chose "Update Firmware"
    • Confirmed version number
    • Began update
    • Sat quietly for 2-3 minutes whilst the progress bar progressed
    • Saw "update successful" window
    • Waited a moment, then reconnected to the MōVI
    • Verified that everything was set to zeros
    • Loaded saved config from above
    • Set "Autotune" to 75
    • Ran it
    It worked
  6. Gary Haynes
    Steve it's a good idea to delete the old config program before installing the new one. That would also be the same for the other platforms.
  7. Steve Maller
    The Android one recognized that it was upgrading, and upgraded in place, and I'd actually never installed the Mac version before, so that wasn't an issue. And I still haven't installed the Windows one. :)
  8. Andy Johnson-Laird
    Steve:
    I presume "Downloaded newest Mac configurator" means "Downloaded and installed?"
  9. Steve Maller
    Sorry, I'm a Mac guy. I'm prone to oversimplifying things. It's the Apple way.
    Yes, downloaded and installed. :)
  10. Andy Johnson-Laird
    I hear ya. It just works. :)
  11. Adam Brennan
    Adam Brennan Member
    Dec 29, 2013
    235
    14
    Thank you Steve Maller and Andy!
  12. Pete Maughan
    Pete Maughan Member
    Mar 1, 2014
    75
    11
    Also had a problem updating firmware, seemed to hang while in the process, I left it for half an hour but progress bar didn't move so restarted everything. Can connect but now no response from gimbal at all. Definitely don't do this update until you have some time on your side...very disappointing.
    Pete
  13. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    Do you have solid lights on the MoVI? If so check your stiffness settings. If your connecting to your MoVI then it is not bricked
  14. Pete Maughan
    Pete Maughan Member
    Mar 1, 2014
    75
    11
    Hi Brad,
    I get 3 lights at initial boot up but then they turn off and no lights after that, after connecting there are no parameters to adjust, just says memory bank. On attempting to restart the firmware update it's asking for the bootstrap jumper?
    Any fix much appreciated, I've sent an email to support.
    Cheers
    Pete
  15. Brad Meier
    Aug 14, 2012
    749
    66
    Just curious what system were you using to update the firmware? It shouldn't be hanging for a half hr. It can run up to 5 or 6 min though.
  16. Pete Maughan
    Pete Maughan Member
    Mar 1, 2014
    75
    11
    Using a Mac.
  17. Adam Brennan
    Adam Brennan Member
    Dec 29, 2013
    235
    14
    I used a Mac and had no issues FYI.
  18. Pete Maughan
    Pete Maughan Member
    Mar 1, 2014
    75
    11
    Little update on my "bricked" M5, seems my Mac must have interrupted the update process somehow with power saver, screen did dip it's brightness during update so that must have been it. This results in needing a jumper cable to allow the process to restart. So worth making sure any power saving or screen saver is disabled.
    Freefly support has surpassed my expectations, getting back to me on a Sunday. That's worth a lot.
    Pete
  19. arnaud Cousin
    arnaud Cousin New Member
    Jul 23, 2014
    Hello ,
    I have exactly the same problem than Pete , I don't know what to do and I have a shoot Tomorow.
    Can I comunicate with the Movi with a cable to reboot. In bluetooth it's impossible for the moment.
    I have the same message than Pete , asking for the bootstrap jumper and I don't know what it is.
    Really need Help .....
    Thank you
  20. Pete Maughan
    Pete Maughan Member
    Mar 1, 2014
    75
    11
    Hi Arnaud,
    I received my jumper this morning and that fixed the problem but you really do need it so get onto support asap and get them to send you one. Where are you based?
    Pete
