2 axis star plate doesn't match pulley wheel ?
Discussion in '3 Axis Gimbal' started by Jose Luis Ocejo, Sep 29, 2012.
  1. Jose Luis Ocejo
    Jose Luis Ocejo Active Member
    Sep 20, 2012
    581
    44
    Hi I started to install the 3 axis to my 2 axis gimbal I bought them at the same time but only use the 2 axis untill now, i notice that the star plate 4 insert threaded holes don't match the outer holes on the new design wheel pulley.
    also the star plate comes with threaded inserts and the pulley too so am I going insane or there is an ovious solution or some how I got a wrong plate or wheel thanks photo.JPG
  2. Josh Lambeth
    1,313
    214
    You run the bolts through the slits in the star plate. They do not get threaded into the 4 spots in the star plate.
    Josh
  3. Jose Luis Ocejo
    Sep 20, 2012
    581
    44
    Hi Josh thanks so only the 4 inner screws hold the star plate on to the wheel correct? if so, I take it that there is no need for 8 screws like before ? the wheel also has threaded inserts on the bottom side
  4. Daisuke Ide
    Daisuke Ide Distributor
    Jul 26, 2012
    34
    Please Hold by hand from the center hub. You rotate the pulley.
    Screw holes of the hub and pulley will be a straight line.
    [​IMG]
    [​IMG]
    [​IMG]
    Daisuke
  5. Josh Lambeth
    1,313
    214
    Ahh you beat me to it. I was just uploading that picture! HAHA
    Yup do what he just said!
    Josh
  6. Jose Luis Ocejo
    Sep 20, 2012
    581
    44
    Thanks Guys I glad Im not going insane just a little Duhh on my part
  7. Jose Luis Ocejo
    Sep 20, 2012
    581
    44
    Forgot.... No Spacers needed any more?
  8. Daisuke Ide
    Jul 26, 2012
    34
    I think I do not need anything else
