1500 masl
Discussion in 'Cinestar 6' started by Gustavo Rios, Jul 17, 2014.
  1. Gustavo Rios
    Gustavo Rios Member
    Sep 28, 2012
    236
    Hello,
    I think make flights over 1500 masl. and more, which firmware I need for this, I have a spektrum Dx8 and Fc 2.1 with 0.90j and Acc upgrade. Some suggestion ?
    Gustavo.
  2. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    881
    70
    Gustavo as far as I am aware it is not a firmware issue you have to worry about its more battery life and trying to keep warm!!
  3. Steve Maller
    Are you lifting off from 1500m ASL or are you ascending 1500m?
  4. Gustavo Rios
    Gustavo Rios Member
    Sep 28, 2012
    236
    Ok Jason, thanks
  5. Gustavo Rios
    Gustavo Rios Member
    Sep 28, 2012
    236
    I will take off from 1500 and more
  6. Denis Gliksman
    Feb 21, 2013
    37
    Hi,
    I guess you speak about Mikkrokopter FC's
    If you go higher than ≈ 3000m you will need the 2.5 FC ! (check on the wiki the exact limit.)
    With 2.1 FC there is a limit for altitude control.
    If you feel you can fly with no altitude control it works but ... failsafe with go home will not work without altitude control ;-) ...
    You will also loose some performance & flight time, considering 10% for each 1000m is a minimum to check.
    regards
    Denis
  7. Gustavo Rios
    Gustavo Rios Member
    Sep 28, 2012
    236
    Yes, is Mikrokopter
    Then, in manual mode I can fly above 1500, 2000, 4000 meters without problem with the firmware 0.90j ????,
    regards,
    Gustavo.
