Hey Freefly... any way to make a software update so your power outputs support more amps? The cameras 6amp and the other 2x are 2amp but these 2amp cant power a small rainspiner or tomahawk? Thx, J
Jason: I very much doubt that the power output is software controlled -- I suspect it would require a hardware change and that implies that it's a less-than-easy fix! I could be wrong, but that never holds me back. Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
We've also had issues. What we have successfully done is use a D-Tap splitter and powered camera and the higher power-hungry accessory off the same Camera output dtap. We've done this powering an Epic and Preston FIZ system all day without issues. Josh
Yeah the camera power is supporting camera, Tomohawks, spinner. For software update, Who knows but the latest beta Fixed the 12 V above the power switch, it now works with the Tomahawk because it didn't before
