Did a land survey yesterday, and it was quite interesting. I had to fly about 550m from the takeoff point at about 120m in altitude. I carefully monitored the Graupner receiver strength, as that was the weak link in the chain, so to speak. The copter performed brilliantly. I used a slightly heavier lens than usual (oops) on my M5, so I was also a little concerned about power and heat, but neither was a concern. I had a perfectly clear picture in my downlink through the entire flight (1.3gHz CP on both ends). I did have to do a little dancing to keep my mx20 TX a few feet away from the video RX, as the receiver signal strength varied from 30% to 60%. I flew the entire flight in Dynamic Position Hold and Altitude Hold because I was concerned about staying perfectly on course. I also had an Xbee hooked up so I could monitor the location of the copter on the map and make sure I was exactly at the edge of the property. Below are a few photos showing my friend's rough outline of the flight path, the trace in real time from MKTOOL running on my Mac under Parallels, and the animated flight path from Google Earth tracing my actual KML file. The GPX data below does show motor 7 lower than the others, but that's because of a miscalibrated BL. I just haven't gotten around to recalibrating it. Flight date: 8/22/2014 11:46:05 AM Flight time: 11:46:05 AM.0 - 11:56:57 AM.8 (652 secs, 00:10:52) Batt. time : 649 secs, 00:10:49 Elevation(GPS) : 0 80.81 119.487 m (min/avg/max) Altitude(Barom.): -0.1 86.14 127.8 m Vertical speed : -3.14 -0.01 2.81 m/s Max speed : 23.9 km/h Max target dist.: 16.8 m Max distance/LOS: 517 m / 531.8 m Sats : 9 10 12 Voltage : min. 21.2, max. 24.9 V Current : 0.5 69 93.2 A Wattage : 11 1547 1994.48 W Capacity: 12361 mAh Motor1: 0.0 8.3 13.7 A Temp: 28 31 36 °C Motor2: 0.0 7.4 14.5 A Temp: 24 30 35 °C Motor3: 0.0 9.6 16.1 A Temp: 28 35 42 °C Motor4: 0.0 9.4 16.5 A Temp: 27 35 42 °C Motor5: 0.0 9.8 15.9 A Temp: 26 35 39 °C Motor6: 0.0 8.3 13.7 A Temp: 26 33 40 °C Motor7: 0.0 5.4 11.5 A Temp: 28 33 38 °C Motor8: 0.0 8.5 14.0 A Temp: 27 31 36 °C Magnet Field: 97 100 106 % (ok) Magnet Inclination: 57 62 70 deg
The BLs' current sensing can be adjusted by connecting to a BL in MK Tool, feeding it a signal, measuring its current draw on a meter of some sort, then adjusting its current sensor to match what the meter says. I've not done that, partly because I don't have a meter that'll measure amps that way.
I can see the window in the "Settings" section here: http://www.mikrokopter.de/ucwiki/en/Single-BL-Ctrl_3 but what signal do you feed in? Perhaps you use the MK Tool Motor Test and set the Motor Throttle to 50% and then use an Ammeter in series with the LiPo to measure what the motor (and the flight avionics) are pulling out of the battery? But if you have the motor test running, can you keep it running while you switch to the BL-Ctrl window shown on the web page above? Andy.
By the way, I notice the instructions at: http://www.mikrokopter.de/ucwiki/en/Single-BL-Ctrl_3 say: "press button "Strg" on your keyboard and hold it down." Anyone figure out what the "Strg" button is? Andy.
I believe that's the Ctrl or Control key. http://en.wikipedia.org/wiki/Control_key Abbreviations in the language of the keyboard layout also are in use. e.g. the German layout uses Strg as required by the German standard DIN 2137:2012-06.
No, it was solid for the whole flight. I was listening intently to the Fraulein (Graupner mx20's voice prompts) telling me the receiver signal strength and it never dropped below 30%. I noticed dramatic differences as I was flying if I moved ever so slightly or tweaked the antenna. And before I flew I moved my GR24 to a more diagonal configuration relative to the launch point, which helped. I know of at least one guy who's moving to UHF for his big octo because at these distances the 2.4 signal is not as reliable as UHF. But of course you lose the telemetry, so it's a tricky proposition.
Thanks Steve. Sometimes I have telemetry loss at 150 meters even the antennas are positioned well. I use something similar to this: http://www.quadrocopter.com/Cinestar-Antenna-Mount_p_1325.html Even though the telemetry is lost, I still have the control of the copter.
I think the issue is that the telemetry from the copter to the ground is coming *back* from what is the Graupner radio *receiver* being used as a transmitter. I'm not sure of the details, but I suspect the *receiver-acting-as-a-transmitter* is not radiating anything like the same power level as the Graupner transmitter in your hands. What I suspect this then translates to is that the telemetry signal from the copter is much, much weaker than the command and control signal from the ground-based transmitter. This would explain why you lose telemetry but do not lose command and control. Andy.
I have had times when listening to the voltage level, the Fraulein would say "Input voltage 0.0 volts", which needless to say sent chills up my spine. I wonder if that was a temporary loss of the telemetry signal. But ever since I got more conscientious about the placement of the receiver and the antenna, I've not heard that particular hiccup.
I've noticed that too. I figured it was just a feature where the Fraulein wanted to see if I was paying attention. I'm not sure whether it's signal loss or just a momentary glitch in the telemetry system. It does, how does one say, focus the mind when you hear 0.0 volts, doesn't it? Andy.
My telemetry interval is set to 5 seconds, which about as long as I can stand, frozen in terror, without any pulse or vital signs.
