TERO/360 Mount
Discussion in 'Freefly Tero' started by Terry Isaak, Jun 1, 2016.
  1. Terry Isaak
    Terry Isaak New Member
    May 16, 2016
    Has anyone successfully mounted a 360 camera to their TERO? I would like on to be mounted at 5' above ground. I am concerned with roll over, inverted pendulum effect, starting and stopping.
    Does anyone know a custom plate manufacturer that could fabricate a plate to be mounted to the underside of the chassis?
  2. Philip Lima
    Philip Lima Member
    Feb 18, 2014
    65
    I have done this, but I did not run the Tero anywhere near full speed. I used it for a slower paced shoot where the tero just had to pace a few people walking. I simple attached a monopod to the anti-vibration plate and then attached our 10 camera GoPro rig to the other end. The camera rig ended up being just over 5ft off the ground and once I was moving I had no problems with pendulum effects, it was actually pretty smooth.
  3. Joey Khan
    Joey Khan New Member
    Jul 27, 2016
    Hi there, not a Tero owner (yet), can you mount pretty much anything to the anti-vibration plate you've mentioned? Like a tripod head for example? Also interested in doing the monopod. I know things other than the Movi aren't supported by Freefly as being mountable, just curious as to what else is physically possible.
    Thanks,
    Joey
  4. Leo Bund
    Leo Bund New Member
    Sep 18, 2012
    16
    Hi There
    yep we've successfully done, we use the 8 camera set up on the Tero alot and it works a treat. Its not just bolting it to the cheese plate, you need to stabilize the rig too.
  5. Arthur Vieira
    Arthur Vieira Flight Squad
    182
    23
    Not a Tero and a little old photo... with a 6 camera head, now we use a 7 camera head, but the setup is almost the same. Just strap a monopod to the cheese plate with some downforce so it doesn't move a lot. Quick and efficient for a setup in a hurry.
    Don't forget a FPV system to drive a car from a remote location or you will be in the footage :D.
    Good Luck!
    Humberto Barchini likes this.
  6. Kevin Binnemans
    Kevin Binnemans New Member
    Nov 13, 2013
    I want to make this with the M15
