Single Op focus
Discussion in 'MōVI Pro' started by Mike Moghaddam, Apr 22, 2017.
  1. Mike Moghaddam
    Nov 10, 2016
    32
    I recently had a small Movi job where I didn’t have a focus puller. It worked out because it was all wide lenses and stopped down but I was looking for something with a thimble wheel type controller for those type of jobs. I already own a WCU-4 so I’m not looking to spend a lot of money since I am happy with my WCU-4 for normal jobs with a focus puller. Another possible use would be as a separate iris control from my focus control on larger jobs.
    The systems I looked at so far are the Redrock Handheld Bundle and maybe a Bush Pilot for the Iris stuff. I’m concerned about mounting the Mimic with the Bush Pilot directly to the ring since when the Mimic is super close to the Movi it freaks out. I’ve also seen a lot of posts about people having problems with Redrock focus stuff.
    I was also looking at the Hocus Smart roller but it’s considerably more expensive and on backorder. Since I’m happy with my Arri focus system I don’t know if I need that nice of a system for these small jobs.
    I’m open to any other ideas or combo of stuff. I’ll be at NAB so I can check stuff out.
  2. Roy Mills
    Roy Mills New Member
    Dec 3, 2014
    15
    This might be of interest to you, its been more than a year in the making and I'm sure it will be out shortly after NAB, I actually got the chance to play with it last year.
    https://shop.redrockmicro.com/eclipse/
  3. Graham Futerfas
    Graham Futerfas Active Member
    649
    140
    I put the Mimic\Bush Pilot on the Movi Ring as a test to see if I could focus myself, and it worked OK. I took the antenna off because of the close proximity.
    Other people have liked the Remote Live 2 from Ikan. Maybe search YouTube for a video review of it by Stephan Knight?
    Here's Pics of my Bush Pilot setup:
    Justin Scott Brown likes this.
  4. Justin Scott Brown
    Justin Scott Brown New Member
    Nov 2, 2016
    What clamp are you using?
  5. Graham Futerfas
    649
    140
    Hi Justin, let's see:
    -1x Impact Atom Clamp to mount to the Ring (I love this clamp! I keep three in the kit):
    https://www.bhphotovideo.com/c/product/831804-REG/Impact_me_100_Atom_Clamp_with_Ratchet.html
    -2x Ultralight 1/4-20 ball Joints, plus one Ultralight knuckle ( I recommend looking for the 'Sue's Knuckles' version, which has a bit more flexibility in the mounting options)
    -I needed a 1/4-20 extension to get out past the Freefly mount on the back of the Mimic, so I screwed together two little adapters from Small Rig:
    1x 1/4-20 male to 3/8-16 Female, and 1x 3/8-16 male to 1/4-20 female. Those are the little knurled gold pieces sticking out the back of the Mimic in the photo.
    Probably have a 1/4" lock washer between the Ultralight and the Impact Atom clamp to keep it tight.
  6. Kevin Sawicki
    Kevin Sawicki New Member
    May 24, 2017
    I recently purchased this for small jobs:
    Remote Live 2 Single Channel Compact Focus Control Kit (PD Movie) - $949.99
    http://ikancorp.com/productdetail.php?id=1866&model=pdl-f
    Works very well, easy to use and has a nice small thumb wheel so you can keep your hands mostly on the rig.
  7. Kazu Okuda_
    Kazu Okuda_ New Member
    Apr 25, 2017
    I think I'll give this a shot. But was wondering if i wanted to, can I connect this straight into the Movi Pro MDR and use the bush pilot with it also for a puller?
  8. Gary Haynes
    5,151
    443
  9. Kazu Okuda_
    Apr 25, 2017
    Hey Gary. I'm looking at the post to change it to add by last name but this is my real name.
  10. Deniz Ozgoren
    Deniz Ozgoren Support Mage
    Dec 17, 2015
    169
    30
    There shouldn't be any problem if you remove the antenna in that kind of configuration (I haven't had any issues).
  11. Bryan Edmonds
    Bryan Edmonds Freefly Staff
    Jul 3, 2014
    146
    75
    Here is a photo of how I rigged our single op focus setup on the Ring Pro, with the Bush Pilot + MIMIC for NAB. The Pop-N-Locks made it quick work and super adjustable/configurable.
    Graham Futerfas likes this.
  12. Enorblack
    Enorblack New Member
    Jul 18, 2017
    I just have the MOVI PRO, because my RONIN was damaged after using it for 2 years. I loved the thumb controller by DJI for the RONIN . Now using the MOVI PRO, which is a HUGE difference compared to RONIN, there are absolute no bumps in my footage. But, I still miss a thumb controller as single operator to move the gimbal by myself. So I am following this post on having the MIMIC on the ring, but how does this work anyway? Shouldn't you move the MIMIC in order to move the gimbal?? It would have been nice to have the ring in upward position and hold it tight and have the gimbal go upwards or 90 degrees down with a controller only...
  13. Graham Futerfas
    649
    140
  14. Enorblack
    Jul 18, 2017
    Thanks Graham. The Aerialpixels one I had for my RONIN before I bought the RONIN thumb controller, that one is not durable, it broke 3 times (cable)...I will check out the redrock...I still hope Freefly is going to make a thumb controller also
  15. Graham Futerfas
    649
    140
    Well, I won't say the RedRock Navigator seemed durable when I saw it at Cinegear in June. Maybe it wasn't the final product? I felt like it could break pretty easily, but the whole joystick thing doesn't work for me.
    Your other options include building your own joystick with the Freefly API and Arduino, but you'd have to make it yourself and that stuff looks way more complicated than a project I've been brave enough to tackle myself, personally. If you can do it, I think you could make one really inexpensively. There might also be a way to mount the Sony PS4 Gamepad and the Mimic to the Ring, which is more durable but also a lot bigger.
  16. Bryan Edmonds
    Jul 3, 2014
    146
    75
    You could also use the Pilot Iris/Zoom module with the MIMIC as a single op joystick on the Ring Pro.
    • Go with the standard 30mm rosette mount if you want the module to be horizontal (perpendicular to the ring). This might be handy so that you can support the weight of the gimbal by the ring, and reach up to the joystick with your thumb.
    With firmware 1.3.2 the dual op adjustments for expo, smoothing and window settings in the MōVI app apply to all pan/tilt inputs, from all sources. So you can really dial in the feel of the force joystick of the Iris/Zoom module. And I recommend mapping the slider to Speed Adj for easy access. Also, the A button is pre-programmed (will be user definable in the future!) to start/stop, so you can trigger any compatible camera connected to the Pro with the proper start/stop or RCP cable, right from the module.
    Chris Olson likes this.
  17. Mike Sutton
    Mike Sutton Member
    Apr 23, 2013
    63
    18
    I have been using a pre release redrock micro eclipse Navigator with Atlas motor and also SLS motors. I have to say the wait has been worth it. This combo is pretty amazing and also allows for pan tilt ans roll in addition to fiz.
  18. Ben Platts
    Ben Platts Member
    Jan 24, 2013
    162
    20
    #18 Ben Platts, Aug 11, 2017 at 8:42 AM
