SBUS Dragonlink
Discussion in 'MōVI Pro' started by Jason Toth, Apr 20, 2017.
  1. Jason Toth
    Jason Toth Active Member
    May 11, 2013
    274
    43
    Anybody using a dragon link on the movi pro, the range with the 14SG is not enough, so set up dragonlink with sbus and everything works but the movi pro's pan/tilt drifts? I swap out the futaba RX (no settings changed) and it works perfect?
    Thoughts?
  2. Jason Toth
    May 11, 2013
    274
    43
  3. Andy Johnson-Laird
    9,578
    1,014
    Can you use the app to monitor the signals being received by the MoVI Pro -- and see what the motors are doing. The evidence you describe suggests that the problem is with the "at rest" signal pulse widths coming from the Dragon Link being slightly different from the Futaba.
  4. Jason Toth
    May 11, 2013
    274
    43
    thx will check it!
