Saving RedRock Motor Settings
Discussion in 'MōVI Controller' started by DanDunn, May 3, 2017.
  1. DanDunn
    DanDunn New Member
    Jan 24, 2017
    15
    Currently running 2 RedRock Micro Torque motors for Focus + Zoom. Everything is updated to the latest firmware (MoVI Pro + MoVI Controller + Mimic). I can get everything to calibrate nicely, but the minute I try to save settings in FIZ Cnfig. on the MoVI Controller, I get a message saying "NO WEDGE CONNECTED" and everything stops working in terms of FIZ. To fix it, I need to power cycle everything, unplug and reset cables, reset lens, mess with torque & speed in FIZ Cnfig so that the motors don't FAULT and re calibrate them. I need to do this a couple times before I can get everything working again. The first few times, the zoom motor just moves in and out, but won't reach any end of the lens.
    Any help is greatly appreciated.
  2. Charles Bergquist
    Aug 15, 2013
    87
    27
    Same, open a support ticket and let me know what happens. I've been trying to get a solution for this for 2 months and they haven't provided me with any solution. I've even sent it in and it they said it's working fine and get it back and it does the same thing. Also, I can't actually get a calibration with Focus at all. Tried 2 different motors.
  3. Graham Futerfas
    Graham Futerfas Active Member
    570
    131
    Does the new Beta Firmware 1.2.5 that came out yesterday help this issue?
    It says BUGFIX: FIZ settings wouldn't save properly in earlier versions of the TSU firmware.
  4. DanDunn
    DanDunn New Member
    Jan 24, 2017
    15
    Graham, tired the new FW today and no help. I can't actually get the motors to work now.
  5. Deniz Ozgoren
    Deniz Ozgoren Support Mage
    Dec 17, 2015
    113
    23
    Can you post version numbers please:
    • MōVI Pro subcomponent versions can be found on MōVI Pro screen under Monitor>Details>Versions.
  6. DanDunn
    DanDunn New Member
    Jan 24, 2017
    15
    GCU Main Application: v1.2.1 TSU Tilt Stage Unit V1.3.1 ESCs Motor Drives V1.0.0
  7. Deniz Ozgoren
    Dec 17, 2015
    113
    23
    Thanks. Some questions I can think of..
    Do you have a MōVI Controller? Can you post your lens setup? How much friction is on the lens do you think from 1-5? Is it always the same fiz port that is calibrating/not calibrating? Does swapping motors on that port make that motor work?
  8. DanDunn
    DanDunn New Member
    Jan 24, 2017
    15
    Hey Deniz,
    +Yes I do have the MoVI Controller -- FW: 3.0.1
    +I've tried on a Canon L 24-105 as well as a couple Rokinon EF Primes
    +2-3 for Friction?
    +Unfortunately not. Today, I can get Focus to work. The other day I had both Focus and Zoom working. On our shoot on Thursday, I couldn't get anything to work.
    +Changing the motors/cables/ports does nothing.
    Sent back our MoVI Pro less than a month ago for a separate issue as well. Not sure if the Wedge would have been checked over as well.
  9. Deniz Ozgoren
    Dec 17, 2015
    113
    23
    • Was this same fw set? Do you remember at all what the versions were? Are both motors Redrock Torque? Do the motors move at all after starting calibration? Do they move without a lens?
  10. Deniz Ozgoren
    Dec 17, 2015
    113
    23
    Also what torque settings do you have on MōVI Controller..
  11. DanDunn
    DanDunn New Member
    Jan 24, 2017
    15
    +RE Thursday shoot...the FW set was whatever was right before the one that came out on Friday (TSU V1.3.1).
    +Both motors are Redrock Torque
    +Focus Motor will currently move (as of the past 10 minutes.) I have had the issue where instead of calibrating, it will just move a tiny bit. As for the other motor, it just keeps faulting.
  12. DanDunn
    DanDunn New Member
    Jan 24, 2017
    15
    +Torque settings - I cycle through randomly until I can get the motors to not fault. That's a quick fix I found on a thread and works sometimes...
  13. Deniz Ozgoren
    Dec 17, 2015
    113
    23
    Something to try: select the motor type for each axis, save settings, then load settings from wedge/fiz axis config screen..
  14. DanDunn
    DanDunn New Member
    Jan 24, 2017
    15
    Just tried...now all motors "Fault."
  15. Deniz Ozgoren
    Dec 17, 2015
    113
    23
    Have you done "Reset" in Wedge Main? That clears faults and lets you calibrate. Did you get all faults even after doing that?
  16. DanDunn
    DanDunn New Member
    Jan 24, 2017
    15
    Yes. Reset in WEDGE MAIN Menu and they are all still faulting.
  17. Deniz Ozgoren
    Dec 17, 2015
    113
    23
    "Still having issues with 2 motors at once. At least one always seems to fault. Sometimes I can get Focus to work, but not Iris or Zoom."
    Has it always been Focus that is working?
  18. DanDunn
    DanDunn New Member
    Jan 24, 2017
    15
    No. I had both working a few times. Focus has been the least finicky.
  19. Charles Bergquist
    Aug 15, 2013
    87
    27
    Mine is still not calibrating. I've gotten it very rarely to calibrate though, 1 in 50 times.
    MoVI Pro FIZ isn't reliable for real work yet though I'm afraid.
