Safe/Legal Transportation of MoviPRO Batteries
Discussion in 'Batteries & Power' started by Gabbo Marvasi, Sep 24, 2017.
  1. Gabbo Marvasi
    Gabbo Marvasi New Member
    May 9, 2017
    Hi guys,
    with how many MoviPRO batteries can I fly according to airplane regulation within the US and internationally?
  2. Graham Futerfas
    Graham Futerfas Active Member
    720
    157
    You can carry on as many as you like, or or at least as many as can fit. You can't check them in your luggage, but they're under 100wH, so you're not limited if you bring them in your carry-on. You should tape the contacts, and maybe have individual baggies handy for them, in case the TSA complains.
    The chargers can be checked in luggage if you want.
  3. Andy Johnson-Laird
    9,657
    1,028
    I'd also suggest that you have a printed copy of the FAA regulations ready just in case the TSA person is unaware of them: https://www.faa.gov/about/office_or...fo/media/Airline_passengers_and_batteries.pdf
    As Graham suggests, you might also want to tape some strong plastic over the connectors (see item Q5/A5) in the above.
