That's a good question, Jason. I've just been looking for a few minutes.... Does this help: https://freeflysystems.zendesk.com/...trol-Firmware-Default-Settings-Bug-2016-8-31- Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limitâ„¢ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
Thx! Our Alta's don't have a default preset but will check out the below when we have time Connect to the ALTA using the App Navigate the ALTA App to Monitor > Open Terminal > Default Config Apply the Default Configuration While in the Terminal, select Reboot Controller Allow the ALTA to reboot in order to save and initialize all flight control parameters
I think that might do the trick -- sorry -- I was away from my office when I responded so I've not been able to try the App with the ALTA. Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limitâ„¢ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
