Reduced speed pan engine
Discussion in 'MōVI Pro' started by jefferson guimaraes, Jul 14, 2017.
  1. jefferson guimaraes
    jefferson guimaraes New Member
    Jul 14, 2017
    Hello, I have two movi pro and I feel that one of them is responding to the slower pan of the other, even the two being the window closed and the response softening very low
  2. Graham Futerfas
    Graham Futerfas Active Member
    623
    136
    Not sure that I understand your question, but maybe you can try increasing Pan Hold Strength. That helps the Pan responsiveness a lot.
  3. jefferson guimaraes
    Jul 14, 2017
    In theory yes, but I have the same values of the two movipro, so I should have the same speed of response .... but this does not happen, one has a slower return than the other, and all the other values are the same in Two movipro
    9,574
    1,012
    Jefferson: How are you controlling the MoVI Pro? MoVI Controller or RC Transmitter?
  5. jefferson guimaraes
    Jul 14, 2017
    Controlling for movepro, without using dual control!
    9,574
    1,012
    OK, so you're using the MoVI controller. Thanks.
    1. Are both MoVi Pro's carrying the same camera, cables, accessories? Or do they have different setups, please?
    2. If you move the MoVI Pro's by hand in the pan axis, with the power off, do you detect any resistance to movement?
  7. jefferson guimaraes
    Jul 14, 2017
    1 realized this difference in speed of movement and mounted the two only with the body of a camera red, with the same configuration values, including window and smooting of pan, plus the return of it is much slower in comparison with the other .
    2 Do not feel any motor resistance when move it off!
  8. Andy Johnson-Laird
    9,574
    1,012
    Hi Jefferson: That's really puzzling -- I don't recall anyone raising this as an issue before -- which doesn't mean it's not a real question -- it's just that you're the first! I suspect the best thing to do now is to open up a support ticket by sending an email to Freefly Support (support@freeflysystems.com).
