Pics of hacking a cordless phone system for Comms.
Discussion in 'MōVI M10' started by Ben Huddleston, Oct 27, 2013.
  1. Ben Huddleston
    Sep 21, 2013
    115
    21
    So I just hacked the Panasonic DECT 6.0 plus base station to make the phones work out in the wilds as a PL system so I can communicate with operators. I just mimicked what I saw the Freefly guys doing, and here are a few pics of how it all worked out. For the record, I am not an engineer, and you do all this at your own risk.
    Cordless phone sets need a "base station" in order for them to work as comms between the handsets. Normally the base station is in your home plugged into the wall at the main phone. Here I dismantled that main base station and put the guts in a small plastic box that can be slipped in a pocket or velcroed to the Tx rig if you like.
    Here's the base station before:
    [​IMG]
    It's not really production friendly in this form. It needs 110v AC power, it's big, and there's nowhere to put it. Luckily, the guts that make it work are pretty small. Four screws and it's open; I just clipped off the red and black leads that charge the handset. (I bought a 3-handset kit, so I have the other two handset chargers.)
    [​IMG]
    So then I tested it out with battery power. The AC power supply said 6.5v, but I wanted to power it with AA batteries, which I haven't had to buy in 10 years (thanks, Baldsound!). So, I took a gamble and tried to power it with 5x AA's, which is actually over 8v with fresh lithiums. 4x AA's would have only been 6v. Most simple electronics can take a little extra juice over their ideal power without frying anything, but this was a gamble. The advantage of using slightly higher voltage is that the batteries should last longer before the base station shuts down due to insufficient voltage. I cut the gray power plug/wire off of the main power supply, and then I bought all the other parts at my local Fry's Electronics. This was my setup just to see if it worked and no sizzling smoke appeared...
    [​IMG]
    Success (at least for the few minutes I left it plugged it). I also cut the green and yellow leads that go to the never-to-exist-in-my-house phone jack, and put some heat-shrink pieces over all the bare wire ends to keep anything from shorting.
    So now, what to house this all in? I found an old jewelry box for cuff links that was the perfect size:
    [​IMG]
    Stripped off all the velvet and padding, trimmed a little notch for the female power connector, and slid it in.
    [​IMG]
    [​IMG]
    I soldered and heat-shrinked the AA battery holders in series and to the gray power plug, closed the box up, and gaff taped it around for a professional look! Attached the AA holders to the top of the box with double-stick tape, and Bob was my uncle.
    [​IMG]
    [​IMG]
    I've tested this setup out for around a half hour, and so far so good. All is working, and no puffs of smoke yet.
    Thanks to Tabb and the Seattle crew for the great idea on how to communicate in real time between operators!
    This is the Amazon link to the kit I bought:
    http://www.amazon.com/Panasonic-KX-...1382928031&sr=8-3&keywords=panasonic+dect+6.0
    Ben.
    Joe Hell likes this.
  2. Nils Ruinet
    Nils Ruinet Member
    Apr 29, 2013
    44
    Thanks for the pictures, looks like a nice and cheap solution !
    Can you use headsets with these ? And are you limited to 2 devices, or can you use the intercom feature between 3 or more handsets ?
    Is the range ok ?
  3. Andy Johnson-Laird
    Ben: Do the phones come with some kind of belt clip or do you just have to stuff them in your pocket?
  4. Ben Huddleston
    Sep 21, 2013
    115
    21
    Yes, I use headsets with these (2.5mm), and you are not limited to 2 devices. I bought the 3-handset kit, but only really plan on using 2, and having the 3rd as a backup or for the focus puller. I knew I was going to cannibalize one charger with the hack job, so I bought the 3. You can buy a set with like 7 handsets if you wanted.
    The range seems to be fine in preliminary tests. Well within the range of the Teradek Tx and wireless follow focus, so I should be fine. I wasn't trying to replace production walkies; just give the 2-3 M10 ops a way to talk unhindered.
    And yes, they do come with very cheap looking belt clips that I expect to have to replace very soon.
  5. Nils Ruinet
    Nils Ruinet Member
    Apr 29, 2013
    44
    Thanks Ben.
    So you can communicate simultaneously between 3 (or more) people using this setup ? Well, this system is starting to sound very interesting if that's the case ! I'll need to have a closer look at these !
  6. Ben Huddleston
    Sep 21, 2013
    115
    21
    That's the word. So far 3 work together just fine.
    bh
    Nils Ruinet likes this.
  7. Nils Ruinet
    Nils Ruinet Member
    Apr 29, 2013
    44
  8. Ben Huddleston
    Sep 21, 2013
    115
    21
    Absolutely. I can't see a reason why it wouldn't. Looks a little bulky though.
  9. Tim Joy
    Tim Joy Active Member
    Aug 2, 2012
    405
    72
    That's a pretty awesome way to get duplex coms! Thanks for posting.
