Phantom Flex 4K on Movi Pro?
Discussion in 'MōVI Pro' started by Graham Futerfas, Mar 20, 2017.
  1. Graham Futerfas
    Graham Futerfas Active Member
    579
    134
    I have a friend who wants to know if it's possible to put a Phantom Flex 4K high speed camera onto a Movi Pro, and I've never done it, but the specs look a little daunting. 14 lbs for the body, and it's a little on the tall side for the cage.
    Has anyone tried this camera on the Movi before? If so, what lenses were you using?
    Also, I can't tell from the specs if it will take 12V, but it looks like it needs 24V power, which may be a separate problem to solve.
    I saw another thread\video here about drones and helicopters, but I couldn't tell if the Phantom was on a Movi or a Shotover or just a water housing.
    Thanks for any help!
    -Graham
    #1 Graham Futerfas, Mar 20, 2017
  2. Dylan Law
    Dylan Law Member
    Nov 7, 2013
    48
    11
    Hi Graham,
    Its a large and HEAVY setup but it can work. We have had it working with Zeiss Standard Speeds and wireless video. Focus was starting to cause a bit of a challenge (but it can be done I am sure). We were powering the camera off a Battery Belt.
    This is what the XL is all about!
    Graham Futerfas likes this.
  3. Mike Sutton
    Mike Sutton Member
    Apr 23, 2013
    61
    16
    Works fine. Flex 4K is actually 12-24V DC so it will work fine but you may want to run with a tethered battery. As far as the weight, the MoVI Pro will hold much more weight than its rated for. The key is to properly balance on all axis and tune accordingly. Can easily be done and has been done many times.
  4. Graham Futerfas
    579
    134
    Thanks! Do you have to remove the top bars of the Movi's cage to fit, or will it take a plate on top and bottom?
  5. Mike Sutton
    Mike Sutton Member
    Apr 23, 2013
    61
    16
    Without the flex 4K top handle and without a baseplate or top cheese plate (that some rental houses have) it will fit fine.
