Hey Alta world!!! In the Alta 6 videos you can see that the tips of the propellers are painted white, has anyone else done this? I think it's pretty smart and easier to see where the propellers are when you are flying. Any ideas of what paint to use so I don't screw anything up?
I'm not quite sure what paint would bond well with carbon fiber - but the larger issue is to make sure that you do not cause the props to be out of balance. If you put just a slight amount more paint on one blade than the other, it will cause major vibrations. Typically to balance non-hinged props you use something like this: https://www.amazon.com/Du-Bro-499-Tru-Spin-Prop-Balancer/dp/B0006N72Y8 -- and when you use one of these you often use small pieces of Scotch tape on the back of a blade tip or sand a plastic prop to remove material. (Yeah, it's that sensitive.) I've not tried to balance the props with hinged blades. I would do a Google search for: carbon fiber paint if you really want to go ahead though. I think you may have to prime the carbon fiber first. Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limitâ„¢ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
