over-current protection
Discussion in 'MōVI Pro' started by Brian Valente, Mar 28, 2017.
  1. Brian Valente
    Brian Valente New Member
    Feb 14, 2014
    14
    Hi Freefly,
    can you give us some insight on how you handle over-current protection for motors in the MoVI Pro lens controller?
    Brian
  2. Chris Benny
    Chris Benny New Member
    May 31, 2015
    19
    I have had 2 Red Rock Torque motors burn out now....
  3. erikmotta
    erikmotta New Member
    Nov 10, 2014
    Hey Chris is this because of the movi pro?
    9,657
    1,028
    Brian: While the tech support mages at FF do read the forum, you might want to email them directly with your question.
    support@freeflysystems.com.
    Graham Futerfas likes this.
  5. Chris Benny
    May 31, 2015
    19
    Hi Eric.
    Still not sure what the cause is. I have emailed both Freefly and Redrock. Will keep you updated.
  6. Dave Beard
    Dave Beard Member
    Nov 15, 2016
    41
    I had an issue with having the maximum torque setting too high on the movi controller. My Heden motors were getting VERY hot. Turned down this setting, and the motors no longer get hot.
  7. Dave Beard
    Dave Beard Member
    Nov 15, 2016
    41
    Chris,
    Were you able to determine what burned up your motors? Do you know where you had your maximum torque value set to?
  8. Chris Benny
    May 31, 2015
    19
    Hey Dave.
    Still no reply from Freefly or Red Rock....
  9. Brian Valente
    Feb 14, 2014
    14
    Chris I checked with our support department and we don't see anything logged from you? we've responded to all questions and there's a separate thread here with some of our observations.
    It looks like current MoVi Pro does not have a way to view or set the torque levels without a tabletop controller, and the default torque value seems to be very high. If you run a motor at 100% long enough it can cause overheating and potential issues. Hoping for an upate from Freefly soon that addresses this.
    #9 Brian Valente, Apr 11, 2017
  10. Dylan Law
    Dylan Law Member
    Nov 7, 2013
    48
    11
    Hey All,
    Has there been any update from Freefly about the overheating issues. We are thinking of getting a Torque Motor and pairing it up with a Bush Pilot. Any info would help.
  11. Deniz Ozgoren
    Deniz Ozgoren Support Mage
    Dec 17, 2015
    180
    39
    If you are using Redrock motors, recommending to get the latest beta firmware which addresses an issue with Redrock Torque Motors https://freeflyeng.s3.amazonaws.com/MoviProv1_2/ios.html This firmware will be going into stable release in about a week.
    TSU v1.3.1
    • Bugfix: Fixes and improvements to an issue reported by customers using Redrock Torque Motors. Added a time based fault that protects in all motion states. It also modifies the over current limit of the Redrock Torque Motors to be lower than what it was previously set to.
    • Bugfix: FIZ settings wouldn’t save properly in earlier versions of the TSU firmware.
  12. Charles Bergquist
    Aug 15, 2013
    87
    27
    This update does nothing for the Red Rock Calibration FIZ issues.
    The MoVI Pro firmware problems could have burned up my Red Rock Motor though, and that's why I can't get it to turn anymore.
  13. Charles Bergquist
    Aug 15, 2013
    87
    27
    MoVI Pro is still faulting or not calibrating.
    Tried different lens motor cables now.
    Anyone else having this issue?
  14. Timm Stemann
    Timm Stemann New Member
    Mar 13, 2017
    20
    Freefly plan to do a major update adressing this issue in the next firmware release. Our CDM-100M was not having any issues in case you need a working version right now.
  15. Graham Futerfas
    Graham Futerfas Active Member
    720
    158
    I'm hoping for a couple of technical fixes in the next update. Who did you hear this info from? Deniz? Customer Support?
  16. Timm Stemann
    Mar 13, 2017
    20
  17. Bryan Edmonds
    Bryan Edmonds Freefly Staff
    Jul 3, 2014
    150
    78
    The motor profile for CDM-100M has not yet been integrated. Updating this motor profile wasn't part of our v1.3 scope. Development of this release has been complete and is about to be released. Our next development cycle (v1.4) will start right after v1.3 is released.
    We will make sure to have CDM-100M integration is part of the v1.4 scope
  18. Graham Futerfas
    720
    158
    Thanks Bryan! Will the API fix for the Alpha Wheels\Mimic integration be in this 1.3 release?
  19. SeBaStIaN BArrEtT
    Oct 30, 2016
    321
    63
    I have a torque motor i have only played around with. Guess I should i put it on the shelf until next firmware?
  20. Bryan Edmonds
    Jul 3, 2014
    150
    78
    We were contacted by the guys at 1A about the issue they were having with the API, after we completed the development cycle for this release.
