http://1a-tools.com/shop/movi-handle-clamps/movi-adjustable-handle-clamps-pair DESCRIPTION Use these Clamps with your existing Movi Handles to quickly and tool-less-ly adjust them on the fly. The adjustable lever provides easy leverage to keep your handles from slipping. Internal threads are high quality stainless steel to ensure high strength and a long lifetime. After locking down, the adjustable lever can be swiveled out of the way. Works with the current Freefly handle design for M10/M15. Early generation handles with plastic on top will not work. HOW TO INSTALL Remove your existing handle from your Movi, setting the small M3 bolts asside, you will need them. Using the same M3 bolts, attach the Movi Adjustable Handle Clamp to the top of your handles. Slide them on to your Movi top bar and tighten the adjustable lever. You’re good to go. TECHNICAL DETAILS Dimensions: 66mm (H) x 36mm (W) x 31mm (L) Clamp Inside Diameter: 25mm Weight: 50 grams Tie Downs Holes: Counterbored for M3 WHAT’S INCLUDED 2 - Movi Adjustable Handle Clamp w/ Adjustable Lever More to come in the next couple weeks!
