MōVI-first time out
Discussion in 'MōVI M10' started by Adam Paugh, Aug 20, 2013.
  1. Adam Paugh
    Adam Paugh Distributor
    323
    78
    Here's a quick edit from this weekend with the M10. All shot with GH3 12-35mm 1080 24P at various locations throughout Northwest Montana. The last half of the video is from Lake McDonald in Glacier National Park. We loaded up on a small 8hp tin boat to assist the boat captain with a disabled steering system.
    Greetings,
    Adam
    Phil Macdonald likes this.
  2. Howard Dapp
    Howard Dapp Active Member
    Aug 18, 2012
    977
    111
    Cool. Refreshing to see those hard mechanical pans from movi in follow mode. Same hard pans (not smooth and rounded) you get with Alexmos when:
    -Follow mode/majestic settings are set a little high or the operator is not smooth and too fast with his panning moves causing the pan axis to play catch up. I also see an ever so slight sign of horizon drift in a couple scenes. It will be interesting to see more movi videos from everyday people.
  3. Brett Harrison
    Brett Harrison Active Member
    Apr 7, 2013
    299
    40
    Hope you didn't do any damage there at the end hehe. Thanks for the demo :)
  4. Adam Paugh
    323
    78
    Yes, certainly still wet behind the ears with this new rig. We were so excited to start using it that we neglected to set up Majestic for the tilt axis. This was all shot with Majestic pan and locked stabilized tilt.
    The bluetooth connectivity is an excellent feature for wireless tuning which we didn't quite get to until yesterday. Our editor took some artistic liberties with the out take at the end. Luckily none of the gear was damaged and I only ended up with a few bumps and bruises.
    Greetings,
    Adam
  5. Steve Maller
    That footage looks awesome. And I must say that a bike crash doesn't really create the same spectacle as a copter crash. :eek:
  6. Sam Fleishman
    Sam Fleishman Member
    Mar 30, 2013
    211
    17
    Love the video Adam.
    any chance we can see a video explaining how the tuning process works? From what I hear its a bit different from how the Alexmos Boards work.
  7. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    hey adam, i loved the boat shots especially. There's one shot u were quite close to the water. Did you take precautions in case of splash?
  8. Adam Paugh
    323
    78
    Hello Charles,
    Yes, I was very careful not to place the rig too close to the water. All of the senors and drives are in weather resistant enclosures, but water and electrical systems never get along well together. Also, water on the lens and the shot is over.
    Greetings,
    Adam
  9. Adam Paugh
    323
    78
    Hello Sam,
    The tuning is fairly straight forward. Each axis is tuned individually after the gimbal CG is achieved. Camera CG is accomplished via quick-release type clamps not screws. There are 3x M3 screws that are used for the big roll bar...this is the only spot you need a tool. It is similar to the Radian system as it relies on proper mounting and then ramping the gain up until feedback occurs and backing off. In Majestic setup I found that there are three main parameters...a gain, a window angle, and an expo. Being able to do this all real time with bluetooth connection is one of the most excellent features of the rig. Set the rig up in the stand...adjust some parameters...run around and see what you think...repeat.
    We can also save settings for different camera/lens configs.
    I'm sure Freefly will have a thorough video guide for setup and tuning.
    Greetings,
    Adam
  10. Kurt Wallrath
    Kurt Wallrath Member
    Nov 8, 2013
    138
    21
    Hey Adam,
    Great video! When you're on the small boat, I noticed the horizon staying level and the boat operator going up and down. Do you (or anyone else) know if there's a way on the MoVI to keep the subject on a small boat level and have the background go up an down? Is this even possible on a MoVI or will it keep trying to make solid ground (aka the background on a lake or sea) stay level leaving the subject going up and down?
    Thanks,
    -Kurt
  11. Kurt Wallrath
    Nov 8, 2013
    138
    21
    P.S. the part in Adam's video I'm referring to is around 2:25.
  12. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    Kurt , u want camera to be leveled with boat . easy ... Hard mount camera to boat. Don't need movi for that . Or do you mean to kill the tilt axis ?
  13. Kurt Wallrath
    Nov 8, 2013
    138
    21
    Thanks for your response, Charles,
    You're correct, I want the MoVI to be level with the boat so the horizon goes up and down as the boat floats, not the subject. However, I want to be able to move around and follow the subject. I suppose I could use a Mantis or other shoulder rig, but I'd prefer to keep the camera on the MoVI as much as possible. Maybe I could try setting the tilt window to 0?
  14. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    I think its possible to set the tilt with the configurator that it becomes almost locked off. I have done that wit the pan when I was using it with the stedicam sled.
