Movi start up off centre
Discussion in 'MōVI M10' started by Andrew Hewson, Oct 10, 2014.
  1. Andrew Hewson
    Andrew Hewson Member
    Oct 1, 2013
    44
    Hey there,
    I've never had any trouble with the movi at all, but today after coming off our cinestar and going handheld we put it on the stand [now pretty much useless due to the toad in the hole touching the ground] and when we turned it on it decided that 45 degress off to the side was centre? We moved the toab in the hole around a bit and it turned the other way.
    Any ideas? We can't get it to actually go centre.
  2. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    You just have to undo the clamp on the toad and rotate until it centers. Depending on your majestic settings, your window setting may be too wide and kinda masking where the true center point is. Temporarily set the Pan window to zero, loosen the toad clamp, rotate the toad until pan is pointed the way you desire and clamp it back down. Reset your Pan window.
