MoVI Pro + RED Weapon 8K Power Issue
Discussion in 'MōVI Pro' started by Qiushi Yu, Mar 20, 2017.
Tags:
  1. Qiushi Yu
    Qiushi Yu New Member
    Nov 7, 2016
    13
    Hi guys,
    I am using a red weapon on a Movi Pro. It seems the camera do not function when using the DSMC2 red Touch 7'' monitor.
    Does anyone had a similar issue before? Please help.
    The Setup:
    Camera: Red Weapon 8K Helium Sensor
    Monitor: DSMC2 Red Touch 7.0’’ LCD
    Monitor Cable: Wooden Camera Male Pogo to Female Pogo LCD/EVF Cable
    Video Transmitter: Teradek Bolt Pro 300 3G SDI Transmitter
    Follow Focus: DJI Follow Motor
    Gimbal: Movi Pro
    Issue:
    The Camera does not function when the monitor is attached. All cables were all good (including monitor cable). I have tried to take the red monitor off the camera and then put it on MoVI Pro. Everything works just fine. Maybe is the Voltage issue?
    Q
  2. Graham Futerfas
    Graham Futerfas Active Member
    733
    160
  3. Qiushi Yu
    Nov 7, 2016
    13
    Thanks for your reply. Besides changing to a smaller monitor. Any solution for this problem so far?
  4. Mike Sutton
    Mike Sutton Member
    Apr 23, 2013
    63
    18
    Movi Pro is capped at 8amps total draw on the three MoVi Pro P/D-taps
  5. Jake Wilganowski
    Jan 5, 2017
    41
    I have a magnesium weapon 6k. I power it with the movi pro camera port. I run the accessory port on the sled to a rtmotion lattitude sidekick. The sidekick has a 2-pin Leno power out, I feed power from this to a cinegears ghost eye 150m wireless transmitter. I run the 7" touch via the movi cable. No issues.
    Brandon Obey likes this.
  6. Jason Toth
    Jason Toth Active Member
    May 11, 2013
    278
    44
    Not sure what all PTAP are maxed at 10amp, the Lipos can output 10x this no problem. I love Freefly products but they all seams to have zero over head.
    M15, never could do 15lbs when moving at reasonable speed
    Alta 6 & 8 are under powerd for their payload capacity
    MPro power can't power much more than camera... rainspinner & Paralinx have issues, the Lipo have enough to power much more.
  7. GavinAsh
    GavinAsh New Member
    Mar 2, 2017
    My first shoot with our new Movi Pro was with an 8K Epic W (Cooke S4i mini), 7" RED touch monitor, Paralinx HDMI Wireless and Redrock wireless follow focus all powered from the movi Pro batteries. Had no problems at all and it seemed to run for 45mins-1 hour for each set of 2 batteries
    Brandon Obey and Graham Futerfas like this.
  8. Jason Toth
    May 11, 2013
    278
    44
    For us we have to power almost everything through the six amp 12 V (Red/Alexa/Tomahawk/Rainspinner) & MDR on one auxiliary 12 V & Semote on the other. The other auxiliaries won't even power the Tomahawk ?
    Would be great if all of them were six amp :)
  9. Brandon Obey
    Brandon Obey Member
    Dec 27, 2016
    35
    Could you provide pictures of you setup? What DTAP cables are you using?
  10. Brandon Obey
    Brandon Obey Member
    Dec 27, 2016
    35
    Could you also provide pictures of your setup? Also, what brand of DTAP cables you using?
  11. Aaron Marquette
    Sep 16, 2016
    31
    What cable are you guys using to power your REDs? I had the same erradic touch screen & camera lock-up with 2 different Wooden Camera P-Tap cables powering from MOVI PRO TSU CAM Port. As soon as we switched to a block battery, the RED booted again. Panavision Woodland Hills' Sr. HD Tech said 'REDs don't like inconsistency-voltage spikes or drops' -eluding to a power issue on the TSU or WC Cable?.
    I've been dealing with a bunch of TSU problems since my 1st MPro job in January '17 so it's in for service now.
