I am making a new thread because no one seemed to have my symptoms. Up until this point The Movi has worked perfectly, and we have been using a Sony a6300 on it with a 50mm prime. No problems that couldn't be tuned out and fixed easily. I tried to boot it up earlier today out where we were shooting, and it threw 5 errors. This is the error screenshots from my phone. (android) Here are the thumbnails, if these don't work, tell me and Ill host on dropbox. The batteries are not the issue, unless 4 separate batteries at 2 houses and 3 different rooms all got contaminated the exact same way to have .3 volts. The Imu/calibration/accelerometer/gyro error cycles through the different ones, and the rest stays the same. Under the other tabs, I get these screens. I have tried default config but nothing changed. I have not tried resetting the firmware completely. It seems like a hardware error to me, nothing seemed loose or jiggling. I do have the controller receiver unplugged from the box, as the cord got severed. I don't think this would have caused a problem, but It is worth mentioning. I do not use the spektrum satellite receiver very much, as we use the Movi mostly handheld. The spektrum receiver is used with a Frsky taranis and an orange rx tx. They have not been used together in weeks. The cord for the receiver itself was pretty mangled, with the wires definitely touching. I don't think this could have fried the entire controller, but who knows. Any ideas? Was really looking forward to filming the next week of storms in norcal.
Evan: Sounds like some serious hardware issues -- you might want to call and/or email to support@freeflysystems.com -- they might be able to walk you through some procedure that corrects the issues... Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
