hi, Does someone can tell me how much is the range of the mimic. In aerial mode, do someone have test and can tell me : Is it as precise than classic controller ? Does is work fine ? Thanks
I have used Mimic for aerials but it's not suitable for shots which will take hours when Mimic is handheld. You can plug Mimic into a fluidhead tripod and use it like that but it's very sensitive to movements. Mimic still doesn't have the scale rate ratio which Movi Controller has. So, to solve this sensitiviy, you will play with window options in the settings. The range is another problem, you will need to use a booster for that. Search for "Movi Controller Booster" on google and you will end up a helpful topic there. My camera operator is getting better results with classic RC controller. Mimic is good for unexperienced operators.
