Mimic and bush pilot issue
Discussion in 'MIMIC' started by Dustin Gunsch, May 18, 2017.
  1. Dustin Gunsch
    Dustin Gunsch New Member
    May 18, 2017
    I am running into an issue with my bush pilot. It's plugged into the mimic and I can't calibrate the controller. Basically it's like mimic is not seeing that bush pilot is not connected. Firmware is up to date. Anyone else run into this issue?
  2. Graham Futerfas
    Graham Futerfas Active Member
    720
    158
    Hi Dustin, with Deniz's help, I just solved a similar issue after updating.
    Bush Pilot stopped working when I went to version 1.2 Beta 2 on Movi Pro, but I had forgotten to update the Mimic to 1.2.1. When I tried to use the Beta App on my iPhone to update the Mimic, it kept failing to update, and Deniz suggested that I use the latest version of the original Freefly Movi Pro app from the app store, which has Mimic version 1.2.1. That solved it.
    Also, make sure Bush Pilot is plugged into COM 2 (on the left side if you're looking at the screen, which is counter-intuitive, but it's labelled that way on the rubber plugs)
    Maybe that will help? If your Mimic is at 1.2.0 and you Movi is at 1.2.1, then Bush Pilot may not work.
  3. Dustin Gunsch
    May 18, 2017
    Thanks Graham for your input, I will look into this today. Hopefully it works out!
