M5: Vibration and erratic bounce on tilt motor
Discussion in 'MōVI M5' started by LLOYD ROSS, Sep 12, 2017.
  1. LLOYD ROSS
    LLOYD ROSS New Member
    Aug 30, 2017
    My M5 has developed vibration and erratic bounce on the tilt motor. It has nothing to do with stiffness settings. I have reloaded software and tried every kind of setting adjustment I'm aware of. My feeling is I may need to replace the motor. I have made a short video of the problem together with (perhaps more revealingly) the associated audio. Any wisdom would be highly appreciated (I live in South Africa, so sending the unit to US would incur major expense).
    Camera setup: A7sII with Canon 24-105 f4
    9,634
    1,028
    Hi Lloyd, welcome to the forum.
    Regarding the M5 -- I can see what you mean -- has anything changed on the M5 setup? New camera? Any different equipment mounted on the M5? Anything loose on the gimbal? If not then open up a ticket by sending an email to Freefly Support (support@freeflysystems.com)
    Hope this helps
  3. LLOYD ROSS
    Aug 30, 2017
    Thanks for the welcome Andy...and I have added my surname.
    I did lend my M5 to a friend who mounted it with an Sony FS5...and it came back with the problem. The camera I use hasn't changed. I rebalanced, autotuned, fine tuned, but no change in the problem. It did all of a sudden come right for a short while, but then (as it would happen), once I took it on a paying shoot, the fault rematerialised.
    I have opened a ticket...thanks again.
    Lloyd
