M10, FS5, CP2 and DJI Follow focus...
Discussion in 'MōVI M10' started by Will Glover, Dec 2, 2016.
Tags:
  1. Will Glover
    Will Glover New Member
    Dec 12, 2015
    18
    Will it balance? Has anyone tried this?
    The problem I keep finding and I had this with the RED Raven too is that the camera is so light, as soon as you put any decent glass on the front you can't push the camera far enough back in the cage which is really annoying because you can fit an Epic with a 1.5kg lens on and it balances fine.
    Weight isn't an issue as we're just handheld and using an exo-skeleton so will add weight to the back of the camera if needs be..
    Thanks in advance,
    Will
