Anyone with the M15 coming from a lot of use with the M10 noticing louder motors? Getting a high pitched hum on the M15...something to bring up with support or is everyone hearing this.
The motors are stronger, so the high frequency occilation is louder for that reason I'd assume. If you balance well you won't hear anything. Don't tune too high and make sure everythig is locked down.
Thanks for the reply guys. I'm going to try pulling in the extended bars a bit and see if that helps remedy the issue. I feel like that might be the problem when using it with an Epic.
