So on a on a Cinestar 3-Axis + 3x radians I would like to set up the tilt axis to be controlled by the throttle stick on the camera controller. The throttle has no spring so it doesn't snap back to center. I'd like it to act like an angle setter instead of a speed setter - if that makes sense. I'm using a Spektrum satellite rx. If I haven't explained well enough, please let me know.
Are you using a dx6i or Dx8? how to set-up is here http://forum.freeflysystems.com/index.php?threads/mode-switch-for-dx6i.160/ You just need to download the software for radians,instructions are there also http://www.freeflysystems.com/products/freefly-radian.php How to videos are found here https://www.youtube.com/playlist?list=PLlKTld1e-W1yImvdV5nuJ8rgNgtozfYnX Next plug in the cable into the tilt radian and assign the throttle through the radian software normally channel 1.
Thanks Jason. I was concerned that the radian would not recognize that Ch1 was different than all the other channels. Guess I'll just try it and find out.
