Help with losing motor vibrations on atv and Movi Pro with black arm
Discussion in 'Camera Mount Misc' started by jim mundell, Jun 11, 2017.
  1. jim mundell
    jim mundell Member
    Jan 15, 2014
    204
    13
    Hi, finally getting around to doing testing with my Polaris ranger and Movi Pro.
    Using the Black arm, 7.5 single springs and testing with A7s2 with 16-35. Wire isolators #2 which may be a little light for this setup.
    My polaris ranger has a certain harmonic vibration at slows speeds that slightly vibrates the entire vehicle. When on throttle at times and backing off. A normal thing for them per polaris dealer. But trying to get eliminate from reaching camera has been tough. When parked I can see the entire movi camera cage moving.
    For steadicam we use 60 durameter neoprene between mounts and vehicle and works well for that. Not so well for Movi pro and black arm.
    Black arm seems to be dialed in well as I dont see many bumps in footage just vibrations that blur footage.
    Any and all help with mounts and movi settings would be appreciated.
