Hi all, We have multiple Graupners and all work fine BUT just got the MC32 & GR-32L - tried everything we know to set it up with the movi and its not working. It should be straight forward: - Movi input = Graupner PPM - Map Movi channels - Bind MC32 to GR-32L - Change telemetry to SUM0 16 - GR-32L port 8 goes into movi Anyone have experience with the MC32/GR-32 w/ Movi - I have searched and can't confirm the PPM out is on channel 8 on the GL-32L? Thanks, J!
I just found a little info - The receiver supports generation of SUMO/SUMI/SUMD signal output on Ch 6 for the convenient use of gyros and control boards. At least we know its Ch6 now - all others are 8, wish companies had constancy between product lines
When you buy an MZ24 it comes with a GR24L and a GR12L. The 24L does everything like normal - its the smaller receiver that does not do SUMO - it only does SUMI and SUMD.
