I would like to get some opinions. When hanging the MoVI off a jib or Black Arm is it correct to select Airborne mode in the Gimbal Application or select Handheld. Also I'm assuming that in Heading AssistSetting the correct setting is Fixed Mount. I am using the MoVI Controller to move the MoVI. Thanks Robert
I use Handheld Application and either Fixed Mount or None. Fixed Mount has the Movi 'Majestically' follow the Pan of the Toad in the Hole... so if you're on a car, and it takes a turn, the Movi will gently follow the turn, so it's less work on the operator. If Heading Assist is off\None, it will always point in the same direction, which may or may not be to your liking. I do wish Fixed Mount could follow the Majestic settings of Smoothing and Window, but it doesn't seem to. It's its own thing. Maybe someone from Freefly can explain it in more precise detail how it determines to follow the panning.
Thanks Graham, I have been using your same settings and really haven't any issues. I will be on a shoot tomorrow and I'll do a little experimenting. Let you know my results.
