Freezing MōVI pro
Discussion in 'MōVI Pro' started by Aidan Kelly, Jan 13, 2017.
  1. Aidan Kelly
    Aidan Kelly New Member
    Feb 21, 2015
    Hey guys on our 3rd shoot with out movi pro now been going well except today we had some issues.
    The major issue was that during flight in airborne mode the gimbal would loose power, once landed the screen on the movi was still on but frozen and motors are off, camera, bolt 2000 are still on the only way to reset it was to take Both batteries off and remove all power then restart movi.
    Fairly heavy setup Arri mini with optimo 28-76 with wc4 with zoom and focus Iris zoom motors. Weather was also hot gimbal temp around 45 degrees Celsius.
    Any suggestions
  2. Chris Herr
    Chris Herr Member
    Jun 20, 2013
    75
    15
    Did you try turning off Set Down Sleep? I was confused by something similar where I would grab the gimbal and it would pause itself. The Pro comes with setdown sleep ON as a default.
  3. Aidan Kelly
    Feb 21, 2015
    Double checked and the Set Down Sleep is not active. Today did not have any issues it may be related to higher temperatures as it was much cooler today. will continue monitoring it and update with any progress. But its not just Set down sleep in any case its a full frozen screen, cannot login via app or move through the menu in the screen.
    Thank for the help if anyone else has experienced this
    Hmm. Don't recall seeing that problem being reported before, Aldan -- you might want to ping FF at support@freeflysystems.com -- please post again once you get a resolution to the problem so others can see how it was solved.
  5. Brice Munn
    Brice Munn New Member
    Jun 17, 2021
    Did you find a solution for this? I’m having the exact same problem. Motor turns off and UI freezes. D-tap power remains on. Seems to happen randomly. Can’t force it to happen with bad balance or excessive movement. It just randomly happens. Typical that it’s usually when we go for a take.
