Fish eye & landing gear
Discussion in 'ALTA 8' started by Jeff Gaunt, Apr 5, 2017.
  1. Jeff Gaunt
    Jeff Gaunt New Member
    Apr 5, 2017
    Hello,
    I'm currently working on a project that requires filming with a Red camera & Canon 8-15mm fish eye set to 8mm.
    As you can see from the example attached, the shot has 180 Field of View. I would like to know if the lens will protrude out past the landing gear as to avoid them appearing in shot. I'm not too worried about the blades as the camera is always tilted down and the image cropped at the top.
    If the lens doesn't protrude past the landing gear, are there any other options to solve this?
    Cheers
    Jeff
  2. Ben Platts
    Ben Platts Member
    Jan 24, 2013
    146
    16
    Is this on a Pro or an M15 or something? We shot with an 8mm on the M15 and just slid the legs in a bit on the carbon tubes until they were out of shot.
  3. Mike Reid
    Mike Reid Member
    Jul 14, 2013
    106
    Your other option is to remove your landing gear and make a little stand for takeoff/landing. I've seen a couple of circular ones that work pretty well, or there is always hand catching. It's pretty easy (and safe) with the alta. Totally doable with 1 person or 2.
    9,480
    996
    Let's hope Steve Maller sees this thread -- he's the master of "ghetto" stands etc. with PVC pipe!
  5. Jeff Gaunt
    Apr 5, 2017
    It's on the MōVI Pro
  6. Jeff Gaunt
    Apr 5, 2017
  7. Jeff Gaunt
    Apr 5, 2017
    Hi Mike can you suggest the best position to hold the aircraft for a hand launch/catch?
    Cheers
    J
  8. Mike Reid
    Mike Reid Member
    Jul 14, 2013
    106
    @Jeff Gaunt I have done it with a single person catching opposite booms, or 2 separate people catching opposite booms. The alta is pretty safe for this because the props are nice and out of the way. Still, be careful though. I prefer the @Steve Maller stand for safety if you have a flat landing surface that you can set it down on.
    Jeff Gaunt likes this.
  9. Jeff Gaunt
    Apr 5, 2017
    Hi Mike, do you have a link to the Steve Maller stand?
    J
  10. Andy Johnson-Laird
    9,480
    996
    Jeff: http://forum.freeflysystems.com/ind...-builds-and-maintenance.738/page-4#post-39472
    See message #71.
    Not sure you could use it for landings unless you're a waaay better pilot than I am....
  11. Jeff Gaunt
    Apr 5, 2017
    Thanks Andy, agreed you would have to be damn good to land on that. I did build a landing hoop out of pvc. I tested it but found it difficult to land in with the disturbance from the rotor wash.
    In the end I have gone for a much simpler approach, takeoff and hover just above head height. Assistant walks in and removes the front landing gear. Need to allow 40 seconds to reattach and land the aircraft at the end of the flight.
    Cheers
    J
  12. Andy Johnson-Laird
    9,480
    996
    Hope the assistant has some body armor and a safety helmet! :)
