hi there, Is there a dual operator mode where the pan is controlled by the movi operator and the tilt controlled by the mimic operator? Can't find this in the app Thanks! Caleb
Hi Caleb: Errr.....I don't think there is such a mode. (But by the very act of me writing that, I'm sure it'll provoke someone to correct me if I'm wrong!) Cheers Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
Well, I have a theory that probably works... but I need to test it more before posting. Under your app's General Settings, change your heading assist to Fixed Mount. Technically, your Mimc would still control the pan, but if you only tilt... The operator still has control of Pan.
See! See! I told you that the fastest way to find the answer was for me to say that I didn't think it existed! <evil grin> (Thanks, Graham!) Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
Actually, because you posted, I was motivated to pull out the Movi and look. Setting to Fixed Mount works... but there's also a Mimic Mode that has Majestic Pan as an Option, so you could also just do it that way.
Well thanks for doing it -- I'm still away from the studio so didn't have that luxury and was forced to go from memory...at least I think I was.... Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
