Controller kills the video output from connex, what to do?
Discussion in 'MōVI Controller' started by Kamil Przybylak, Mar 13, 2017.
  1. Kamil Przybylak
    Kamil Przybylak New Member
    Feb 21, 2016
    20
    Anyone having troubles with MoVi controller and connex? Whenever I use them simultaneously they interfere with each other. When I move the stick on the controller it interupts the video from connex. Can anyone help me on this one?
    Kamil
  2. Chris Benny
    Chris Benny New Member
    May 31, 2015
    19
    Hmm strange. I have been using the Movi Controller and Connex for the last couple of years with no problems. Have you tried different channels?
  3. Mike Gentilini Jr.
    Aug 5, 2014
    45
    11
    Kamil, the Connex and MoVI Controller run on two different radio frequencies. The MoVI Controller is 2.4Ghz and the Connex is 5.8Ghz, so it's old that they would be conflicting. We've never had this issue with ours.
    I would make sure that you have the MoVI Controller on Channel 0 (auto) and the Connex via the software can be set to auto select as well. Try setting the Connex standard (not Mini) to 40 MHz as well, instead of 20Mhz. This will give you a higher quality image as well.
    See if this fixes the issue.
    It might be that the antenna on the MoVI Controller is too close to the Connex receiver's antennae -- and if you get a Tx antenna close enough to an Rx antenna it doesn't matter that they're on different frequencies -- the Tx will blast out a signal so strong that your dental fillings will oscillate....
    Can you increase the distance between the Connex receiver just to see if that makes a difference?
