Cinestar 8 HL - Autonomous
Discussion in 'Cinestar 8' started by RobMartin, Aug 16, 2017.
  1. RobMartin
    RobMartin New Member
    Aug 16, 2017
    I want to auto pilot this beasty.
    What's the best way to make it happen??
    Rob
  2. Chris Ross Leong
    Dec 21, 2016
    34
    Any of the modern flight controllers combined with a ground station and a decent remote app can make this happen.
    For instance, a DJI A3 type FC with a laptop running the a DJI ground control program, Litchi, or UgCS for DJI would work.
  3. RobMartin
    Aug 16, 2017
    Thanks Chris. I'm interested to know if there's any resources that'd detail how this would be setup.
    One thing I've noticed is that these things are all conceptually doable, but practically difficult if you're not in the know.
    Rob
    9,634
    1,028
    Hi Rob, welcome to the forum.
    As to your question, you might want to start here as the Cinestars typically used Mikrokopter flight controller, navigation controller, etc.:
    http://www.mikrokopter.de/en/products/flightplanning
  5. Chris Ross Leong
    Dec 21, 2016
    34
    As Andy has said, the MK system is the original one for the Cinestar, and there's plenty of meticulously detailed setup info on the MK site. Likewise for UgCS, Litchi, DJI and the like.
  6. RobMartin
    Aug 16, 2017
    Thanks Guys. I think I've got it covered now.
    Was a good excuse to join in.
    Looking forward to sharing more.
    Old tech, but an amazing lift machine.....
    Now I need a Red Dragon.. haha
  7. Shaun Stanton
    Shaun Stanton Active Member
    Oct 27, 2012
    747
    127
    It would be similar to how people did DJI Wookong-M builds in the previous years. The main thing as others mentioned you would need to do some out of the box installation. The main thing is constructing some platform that can hold all of the DJI equipment. Like Andy mentioned the original Cinestar was built to place the Mikrokoper ecosystem, which had specific mounting points for their boards. DJI uses little boxes to hows the systems in and typically get tacked on by 3M tape. The tricky part might be finding a Power Distribution System to fit on the plate. You can find such an animal on Famous Hobby which still sells after market Cinestar replacement stuff.
    Like Chris said an A3 using Lightbridge 2 would give you all of the autonomous features of the current Generation of DJI RTF units such as the Phantom, Matrice and Inspire series. You would be able to use several apps that are integrated into DJI's ecosystem such as Litchi, DJIGS, drone deploy, and many others.
    I still have a Cinestar X8 in the picture that I use with an old Wookong as a backup rig for situations to get around the DJI Geofencing. Wookong will fly at an airport where DJI 3rd gen systems require a specific process to unlock. Not saying you should fly at an airport. But I had a shot that was one mile from one and had an airspace authorization, I had to get a special unlock. It worked, but I had my CS8 rigged as a just in case measure.
