I have a Cinestar/Chinastar hybrid Heavy Lift hex and a MoVI M10 that has been upgraded with the top mount conversion and the full cage. I am including everything needed for a complete aerial cinematography set up. Hex comes with Avroto motors, T Motor 15" folding props, DJI Wookong M controller, Futuba 10C radio and Sbus receiver. Toad in the Hole and navigational lights are installed and ready to go. I'll also throw in 3 8000mah flight batteries and a nice charger and power supply. Booms and all wires are labeled to ease assembly/disassembly. M10 comes with MoVI Ring (Toad in the Hole and monitor mount included) and set up stands. Unfortunately the original top handle ran off some time ago, I've always preferred the ring so I never replaced it. You'll also get 4 batts. and the original FreeFly charger. Sbus radio is included and all ready to go. I an also including a pilot fpv setup with VTX, Camera, and 4" Monitor w/ built in receiver that can be mounted to the pilot's radio. You'll also get a 5.8ghz transmitter with HDMI in for the gimbal camera and a 12" monitor with built in receiver. I'll throw in a Samsung Tab for running the MoVI app as well. I am also including an adapter plate for adding 12mm rails to the Hex if you ever want to run a different gimbal or payload. Camera is NOT included. $3200 plus shipping firm. View attachment 10864
