Here it is, the BreakerBatt! Power your SmallHD monitor from external sources while passing the power through to your Teradek Bolt! Will take either polarity 2-pin Lemo from 9-38V! https://mediablackout.net/products/breakerbatt
Looks good but the Teradek has that stupid reverse polarity from everything else. How do you handle that with the pass thru? Also is that 3d printed?
Hi Jim, The pass-through port will pass the same polarity that you put into it. The polarity that Teradek uses (pin-1 GND) is actually more common than the other polarity, but if you do need to change the polarity, we offer crossover cables here: https://mediablackout.net/products/2-pin-lemo-cable - Just select "2-pin Lemo (0B.302) Crossover (1:2)" in the "Input Connector Options" dropdown. The BreakerBatt is a hybrid injection molded and 3D printed product. We own a very high-end 3D printer that can print composite materials like fiberglass and carbon fiber in addition to high quality nylon.
