So I received my M5 yesterday, I already had a dx7s for another gimbal that I have. I plugged my satellite rx into the 3 pin wire that was left dangling, used the android app to initiate binding. Powered the unit off then on, lights flash on the RX then I do a normal bind on the dx7 but it will not bind. Any help would be great
See this post and see if it helps. http://forum.freeflysystems.com/ind...movi-multi-rotor-upgrade-kit.3915/#post-44128
Hi Paul: Can you confirm that what you're doing is this: 1. After you've got the Rx light flashing, you 2. Have the DX7 throttle (left stick) all the way back towards you. 3. While the RX light is flashing, you press and hold the Train/Bind button while you power on the DX7s, keeping the Train/Bind pressed. 4. You wait until the RX light stops flashing rapidly and stays on solidly, and only then you release the Train/Bind button. Can you describe what you're seeing that's different from the above, please? Andy.
