Best Movi Pro settings on Tero / Tilt problem
Discussion in 'Freefly Tero' started by Marco Eisenbarth, Nov 15, 2017.
  1. Marco Eisenbarth
    Marco Eisenbarth New Member
    Nov 24, 2016
    Hey all,
    I've got two things that I was hoping to find the answer to here.
    First: I'd like to know what movi pro settings you'd suggest while working on the tero. What stiffness? What hold strength? I just made the first test drive a couple of minutes ago and the movi was shaking and swinging heavily from side to side. The tero itself also swung side to side. Back and forth it seemed pretty stable.
    I've read multiple times to better not change anything about the tero itself.
    Second: For some reason I can only tilt into one direction while on the Tero. If I adjust the cage slightly above zero degrees I can only tilt up. If I adjust it so be slightly below I can only tilt down.
    Hope someone can help :)
    Thanks!
    Marco
