Batteries not charging
Discussion in 'MōVI Pro' started by Neil Willis, Nov 14, 2017.
  1. Neil Willis
    Neil Willis New Member
    Sep 14, 2015
    29
    Anyone had any issues with the batteries not charging?
    I've got two which will not charge/ hold charge. Its not the charger as my other set work fine.
    These are like new and only been charged about 6 times but not sure if they are covered by warranty?
    Regarding the warranty, Neil, you might want to open up a ticket by sending an email to Freefly Support (support@freeflysystems.com).
    Just out of curiosity, have you stored the batteries fully charged for a long period of time -- I'm not saying that is the issue, but I'd like to know more about their history just in case anyone else has a similar problem.
  3. Neil Willis
    Sep 14, 2015
    29
    Hi Andy,
    I've spoken to the place i got them from and their looking into the whole warranty thing - they were not 100% what FreeFly's policy is. (DJI is only 6 months on batteries) If its the same same then I will be pi%%ed.
    The batts were not full and at a guess around 80% full and were sat for about 3 weeks.
    It seems odd that two batteries would fail...mind you I had four DJI TB48 batteries that "failed" when the "smart" battery controller firmware had a bug that caused them to self-discharge to zero volts.... :(
  5. Neil Willis
    Sep 14, 2015
    29
    I also had a TB48 fail on me with less than 20 cycles - it was 7 months old and DJI told me to jog on :-(
