Amira on the M 15
Discussion in 'MōVI M15' started by Balázs Révész, Dec 12, 2014.
  1. Balázs Révész
    Balázs Révész New Member
    Dec 5, 2013
    26
    10
  2. Tim Sessler
    Tim Sessler Active Member
    Aug 12, 2013
    185
    65
    Thanks for sharing! How much space do you have on the back? Do you have full tilt or does the back of the camera hit against the Roll Bar at some point?
    Cheers
  3. Balázs Révész
    Dec 5, 2013
    26
    10
    Details:
    The busiest part of the year is over so I decided to max out possibilities with my M15. Yesterday we were testing the Dragon with heavy lenses (MP and Angénieaux mid LW Zoom w LMB) no problem.
    It should hold the Master Anamorphics as well since they're lighter than the MPs.
    So we scheduled for today a session with the Amira.
    As you see we attached a V-lock plate w battery on the side with a couple of Bongo ties and the unusable dovetail plates we replaced with two ninja plates. There's some engineering work needed to do it properly but this way the camera can be balanced properly and clearance is good enough to tilt up 75 and down 90+ degrees. It is really on the limit, just the two mini antennas had to be removed from the back top of the camera to achieve this. The carbon V-lock adapter what appeared for the Epic has to be redone for this but I'm gonna make it done one day and somebody else will for sure. So good luck everybody with this and I am very happy Arri can be flown from now without the leash:)))))
    Peace yo
    Andrea Cecchini likes this.
  4. Balázs Révész
    Dec 5, 2013
    26
    10
    The Roll bar is ok, the pan motor was hitting the antennas tilting the camera down so we removed them.
    Isn't it beautiful.
    Here's AMIRA displayed nicely
    The whole installation is around 10 kgs / 22 lbs.
  5. Eric De Fino
    Eric De Fino Member
    Sep 1, 2013
    101
    14
    Amazing. Thanks for sharing!
  6. Andrea Cecchini
    Mar 19, 2014
    33
    Top Balazs!!!
    Share a photo with Movi Ring, please!
  7. Charles Bergquist
    Aug 15, 2013
    89
    28
    Awesome! Been waiting to see if it was possible, nice work! At 22lbs does it still work pretty well? How's your battery situation on the side? Don't have an Amira but it's really intriguing!
  8. Balázs Révész
    Dec 5, 2013
    26
    10
    Thanks.
    Yeah it works well, behaved normally. I have pics w the ring from yesterday with the dragon-MP setup, here it is.
    It is a Dragon, not the Amira.
    One more beauty with the bigeye beast. plenty of room around.
    Can't be told about the Amira. That one fits the M15 with a Compact prime about same how an Epic fit the M10 with an Ultra Prime. But I think that's a huge progress.
    Amira w. CP2
    and an Epic on an M10 in March
    Great Thanks to Vision Team Hungary where I could test as much as I could this last beautiful year to "MAX" things out:)
    (visionteam.hu)
    Ryan Hamelin likes this.
  9. Balázs Révész
    Dec 5, 2013
    26
    10
    And similar amount of thanks to Gábor Komora for the Amira
  10. Ryan Hamelin
    Ryan Hamelin Member
    Nov 1, 2013
    41
    13
    Without the battery on the side of the Amira, does the weight shift the camera too far back? We use our own proprietary power system on the top handle to power cameras and accessories in general since it keeps that weight off the gimbal, but I'm curious to know if the lack of a side mounted battery prevents you from being able to balance the rig front to back.
  11. Kurt Wallrath
    Kurt Wallrath Member
    Nov 8, 2013
    138
    21
    Great job Balazs, you beat me to it :)
    I'd suggest buying longer carbon tubes (25mm) so you can move the Amira farther back. Also, I'd go with the Heden M21 to get the weight down and maybe a lighter wireless ff receiver like the Heden Karat. You may consider placing your power supply above the handle bars to further reduce the weight and increase battery life.
  12. Balázs Révész
    Dec 5, 2013
    26
    10
    Ryan
    Without the battery behind the balance point the camera would have to be more back for balance and hit the Roll bar since the mass of the camera is concentrated around the front (sensor, cooler, PL mount, lens, lens motor, parts inside I have no idea about) and most of them can't really be changed.
    Kurt
    thanks, yes longer bars would be a solution but I'm afraid the pan bars would have to be longered as well. And the motor and sensor cables would have to be longered or detached from the M15 body I wouldn't alter this great equipment that much. I would do it with a kit from Freefly only but that might be called M20:)
    We with my fellow gimbal operator friend Robert Szilágyi - great thanks to him for his creative ideas - cooked with what we had (ninja stars, bongo ties, dual lock, spare screws) and it worked and can be repeated.
  13. Balázs Révész
    Dec 5, 2013
    26
    10
    Charles actually we didn't have scales to measure it with the Amira, 22 lbs. was just a guess.
    Based on measures the day before when we had scales and Dragon with MP21 and LMB was 6,28 kg 13,8 lbs. (Plenty of room around the camera body.)
    The Movi with Dragon MP21 LMB weighed a bit under 10 kgs 22 lbs
    I based my statement about the Amira on this because it felt around the same and
    Amira body 4,5 kg
    CP lens 0,9 kg
    Beillen battery 0,6 kg
    plates cables cca. 0,5kg
    together 6,5 kg
  14. dan mohr
    dan mohr New Member
    Nov 25, 2013
    13
    sweet!
    what hardware do u like to get the M15 plate to the Amira top dovetail?
  15. Balázs Révész
    Dec 5, 2013
    26
    10
    The unusable dovetail plates we replaced with two ninja plates and leftover screws with spacers.
    I say unusable because they are increasing camera height both on top and bottom and the camera just fits with 2 thin ninjas in the cage.
  16. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
  17. Charlie Beyer
    Charlie Beyer Member
    Nov 12, 2013
    70
    What power cable did you use from the CF V lock plate to the Amira body? Was it custom or stock somewhere?
    Did you find that nijna holes lined up with the Amira top and bottom sliding dovetail holes or did you have to pilot noes holes in the Ninjas?
    Excellent work. I put an Amira on my M15 but never removed the Gold Plate on the back nor the small antennas. I figure that a EF lens combined with some kid of counter weight on the body like the MDR would be required to make the balance work. I saw the need for a thin top and bottom plate to mount to the Movi. The Ninja plate seems perfect. FYI I like to wear the Battery in a belt to reduce both the weight on my arms as well as increase the performance of the Movi. Not for everyone I know.
  18. Wolf Schiebel
    Wolf Schiebel Active Member
    Aug 15, 2012
    254
    67
    Hi,
    we did it also:
    Amira was powered by a Bebob V75 V-mount battery, lasts about 30 min. To be optimized…. but so far no issues.. No matte box and internal nd´s though..
    Cheers,
    Wolf
    Axel Rodil likes this.
  19. Kurt Wallrath
    Nov 8, 2013
    138
    21
    Thanks for sharing Wolf! How much did it weigh? Did you need to use a ninja star to attach the M15 dovetail to the camera?
  20. Wolf Schiebel
    Aug 15, 2012
    254
    67
    I guess the weight was about 6 kgs.
    No, i used the Amira topplate, which fits also in the bottom dovetail.
    Best,
    Wolf
