I try to update my alta6.but i have some troubles with it. i have put the sd card in gps box! who can tell me?i need help!thank you very much!
If Gary's suggestion doesn't work, try using a different microSD card and, I know this sounds silly but it's worth checking, check that the microSD card is not wedged in upside down....believe me, some folks have done this (Me? Nah? Never ... at least not on a ALTA...yet! ) True, the microSD card slots are asymmetric to prevent you doing this but, with sufficient determination.... If that doesn't work, with a suitable microSD card adapter see if you can read any data from the microSD card on a Mac or PC. That will at least tell us whether the microSD card is OK or whether it's joined the Micro SD Paper Weight Club (in which case revert to the "try another microSD card" ploy. Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limitâ„¢ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
