OK... just ended a Weekend fliying the Alta with the Red Epic... and for me they are great news... Flying in 33 Celsius 80% humidity, 25 Km wind with at least 35 Km Gusts, 200 feet ASL Red Sacarlet with 25mm Zeiss lens. Movi10. DJI Focus. Coonex Amimon for video. One tattu 4S 3700 mHa battery to feed the Connex, Movi, Focus and the camera. (25 min run time, changing the battery at 30% of remaining power) Two 6S 6.200 35C Tattu Batteries 10 minutes Flight time landing on 21,4 Volts, final cell volt on ground with everything off 3.69 volts 12,5 Kilos total @ takeoff ESC highest temp (when I need to climb at 2- 3 m/s @ 100 meters) 69 degree celsius... (ESC with the new firmware) I hope this helps others with the flight configuration... PS: I put the Mini on the thread name just because I have the same takeoff weight with the mini... so... you all know...
Hi Humberto, where did you buy that cable that is powering up your movi, red, follow and connex ? Or did you make it your self ?
Hi Arnar! Sorry for the delay... Yes it is home made... I can send you the picture if you like! Cheers
Hi Humberto, That would appreciate that very much, I really need this cable Can you aloe tell me what cables you are using, if you have links that would be great. Here is my email: arnar88@gmail.com Thank you
