Just got interested by the design of ALTA 8. Is there any optical flow for indoor positing holding? Does it use Lidar or ultrasonic sensors for low altitude height holding? If there is any, where are they located?Many thanks if anyone can shed light on this
Alan welcome to the forums. Would you be kind enough to change your user name to your real first name and last name, please? The reasons for this (and how to do it) are explained here: http://forum.freeflysystems.com/index.php?threads/real-names.497/ There are not sensors like the ones you describe built into the Alta 8.
Yes I like to use real name to maintain professionalism. Actually have been already using my real first name and now I have added my real last name as my username. Thanks for the reminder anyway. Regarding low altitude height holding and indoor position holding, what sensors do Alta 8 or Alta 6 is using?
Alan: There is no optical flow system on the ALTA's. Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limitâ„¢ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
