Airborne mode - Magestic oscillation
Discussion in 'MōVI MR' started by Chris Lethbridge, Oct 18, 2015.
  1. Chris Lethbridge
    Chris Lethbridge New Member
    Sep 25, 2015
    14
    Hi guys
    Sorry if this has been covered already in another thread, but I'd like to discuss an issue I'm having with my M15.
    I changed the mode from handheld to airborne so that I can use it on my ALTA - with the option of selecting magestic mode so that the gimbal can be locked for take off and landing. However, whenever I select magestic mode for this, the gimbal starts to violently oscillate.
    The stiffness settings are how I want them for dual operator mode - are they too high do you think?
    Chris
  3. Even Sigstad
    Even Sigstad New Member
    Jan 2, 2014
    23
    10
    Hi Chris. Is it oscillating when your on the ground in airborne majestic? If so, thats normal. It should go away ones you take off and switch to dual operator mode. Hope that helps
    Even
  4. Gary Haynes
    Chris, you should do the gain settings while hanging the Alta/MoVI combo. Once you have it sitting on the ground if you were to put it in Majestic mode it might vibrate like it is mis-tuned since it is sitting on the ground and not suspended form the Alta. Put it in kill mode and once in the air switch to majestic.
  5. Chris Lethbridge
    Sep 25, 2015
    14
    Thanks for the response guys. From what I understand it seems that I should just ignore the vibration when it's on the ground? Gary, I adjust the gain settings when the Movi is hanging off the c-stand arms, then I transfer it to the ground/ALTA when it's ready. Is this what you meant?
  6. Gary Haynes
    Chris, yes exactly. If you go to majestic while sitting on the ground in addition to getting the jitters the flight deck will start spinning from the pan moron since there is no resistance.
  7. Andy Johnson-Laird
    The pan moron? Them's fightin' words....You talkin' about me, Mister.... :)
  8. Derek Cooper
    Derek Cooper Active Member
    Apr 28, 2014
    527
    34
    Is that an Alta feature? We're still using Cinestar rigs and can't find the morons.
  9. Gary Haynes
    Good to see that some of you are awake. Gotta love spell chequers....
